paint and decal removal...easy way
3 posters
Got another M3 that I want to remove all the paint and decals from then prep for spraying when I get the color code and was wondering whats the quickest/easiest/safest way of removing all the paint and decals??
When it's all cleaned off whats the best paint and primer to use to paint the shell?? Also lacquer before applying decals or after??
Re: paint and decal removal...easy way
peter is it a 1:43 or 1:18?.............and is it diecast or resin m8?
bmd- Posts : 7018
nitromors or an equivalent product m8....remove all plastic/rubber parts, dunk it in a glass jar overnight, wash/scrub off next day, should do the trick m8
bmd- Posts : 7018
Brown dettol! But it will smear clear plastic. The new Nitromors mixed with cellolose thinner will work well too.
RORY O CONNOR- Posts : 1670
» Ixo/Altaya 6R4 lamp bracket removal
» 2003 Focus Striped, Decal & Tampo Removal Ixo/Atalya
» Paint or decal ?
» Paint Spray
» Neo Metro easy to strip?
» Paint or decal ?
» Paint Spray
