Removing a sunstar subaru body
3 posters
Removing a sunstar subaru body  Empty Removing a sunstar subaru body
Post  Gav_rs1800 Wed Apr 10, 2024 7:54 pm
Hi everyone,
Can anyone help me on how to remove a sunstar 1/18 subaru body form the base, all i see is 2 screws in d middle of it and when removed it wont seperate?
Also where can I get a RHD for the colin mcrae san remro subaru
Thanks in advance
Gav_rs1800
Removing a sunstar subaru body  Empty Re: Removing a sunstar subaru body
Post  bmd Thu Apr 11, 2024 7:29 am
Gav. if i rem correctly the two centre screws only hold the inner tub section to the base, have a look up under each wheel and see if there four srews there....
billy
Gav_rs1800 likes this post
Post  RORY O CONNOR Fri Apr 12, 2024 1:49 pm
There are six screws. 4 are easy to get too. Two under the front wheels, two at the B pillar but there are two under the rear wheels which are tricky to get to, so you'll need a thin screwdriver. When all are out open the rear doors and push the tub out. Front and rear windows are tricky to remove without breaking. If stripping the paint, the door handles are plastic and the vents on the bonnet. The door bandles can be removed by pushing a thin pointed screw driver or mathematical compass from behind the door.
