Car Body Filler
3 posters
Car Body Filler
Ive been thinking about using car body filler instead of milliput for a project but as ive never used it before, how does it stack up against Milliput.
Im mainly looking at its fast drying time as Id like to be able to do all the work in one day. The project will require lots of shaping and sanding as well as more filler/milliput being added. Ill also have to remove the item from the model to be cast in resin. Ive heard a release agent will work on milliput but would it also work on filler
Anyone any thoughts on how they stack up against each other
brian- Posts : 2009
Re: Car Body Filler
colin prob the man to ask on this one m8...he's on facebook more than the forum but i'm seeing him tonight, if you get no replies i'll mention it to him....
bmd- Posts : 7017
Re: Car Body Filler
That would be great Billy Thanks
brian- Posts : 2009
Re: Car Body Filler
As if by magic he returns lol
Brian I would use U-Pol Easy Smooth 7 as it's easy to sand and would be quicker,
The only down side is that body filler can end up with pin holes in it after it's been rubbed,
I would prime the repair let it dry then pick in the holes with 3M Stoppers,rub the stoppers then prime it again,
Overall it would speed things up as you can do the repair,prime,stopper and re-prime all in 1 day,
If you are going to cast in resin then as long as the filler is covered with primer it will work
Cazzo- Posts : 1966
Re: Car Body Filler
Thanks Colin, might give it a go and see.
brian- Posts : 2009
