Removing set of front lights from brookes manta
4 posters
Removing set of front lights from brookes manta Empty Removing set of front lights from brookes manta
Post  Gav_rs1800 Tue Mar 05, 2024 9:13 pm
Good eve,
Would anybody be able to give some advice on how to remove the front lights and indicators on russell brookes ixo manta 1/18 scale
Thanks in advance
Gav_rs1800
Removing set of front lights from brookes manta Empty Re: Removing set of front lights from brookes manta
Post  bmd Wed Mar 06, 2024 9:13 am
mate ive never done an IXO but have done several Revell versions... most are simply plastic dabbed, i use my dremel with small grinding attachment, from the inside.. simply grind off the inner dabs of plastic on the inside and the unit will come out from the outside... a drop of canopy glue replaces them with no colouration so glue is invisible.....
Post  Gav_rs1800 Wed Mar 06, 2024 11:02 am
Thanks a million ill try that this eve and see how i get on 🤞
Gav_rs1800
Post  brian Wed Mar 06, 2024 12:23 pm
You cant push the headlights out from the back it seems. They need to be prized out from the front apparently, but I can see that damaging the unit
How is your german? Let us know how you get on
Post  Gav_rs1800 Wed Mar 06, 2024 5:19 pm
Thanks brian,
I got them out thankfully without any damage, I put a stanley blade where he hammerd in and flicked it out handy as hell
thanks again
now it near ready for painting
Gav_rs1800
Post  brian Wed Mar 06, 2024 5:52 pm
Any chance of a close of picture of the headlight unit and the model to have an idea of what we are dealing with? Would be good to see how its held in
Post  Gav_rs1800 Wed Mar 06, 2024 7:15 pm
No problem at all brian,
Gav_rs1800
Post  Gav_rs1800 Wed Mar 06, 2024 7:21 pm
Removing set of front lights from brookes manta 20240319
Gav_rs1800
Removing set of front lights from brookes manta 20240321
Gav_rs1800
Post  Gav_rs1800 Wed Mar 06, 2024 7:27 pm
Your not able to push them out form the back as the chasis bolt up in behind rhe lights
Gav_rs1800
Post  brian Wed Mar 06, 2024 8:10 pm
Thanks, its good to see how they are put together.
Any other headaches to watch out for or is it straight forward after that
Post  Gav_rs1800 Wed Mar 06, 2024 8:35 pm
No problem at all, no problems after that its a handy dismantle then.
Once done ill show you the end product
Gav_rs1800
brian likes this post
Post  RORY O CONNOR Fri Mar 08, 2024 2:26 am
Looking at the video it is clear the headlamp units and door handles have locating lugs so Id say the light units will push out from behind if you get a small enough pointed tool. I do this with 1/43 IXOs. Saves prising off and possibly damaging the parts.
Post  Gav_rs1800 Fri Mar 08, 2024 8:32 pm
Finally finished not the best but its all learning, not bad for my 2nd modelRemoving set of front lights from brookes manta 20240322
Gav_rs1800
Post  bmd Tue Mar 12, 2024 2:51 pm
good stuff mate Smile Smile
Gav_rs1800 likes this post
