Andrews Heat for Hire PAINT CODES
Andrews Heat for Hire PAINT CODES Empty Andrews Heat for Hire PAINT CODES
Post  modelrallysport.com Thu Mar 29, 2012 11:40 pm
THESE ARE THE CORRECT Heat for Hire Paint codes,i published these on the other forum a while ago then lost them however today i found them again
so thought i would re-publish-------------hope they are of use to you all!
BS. GOLDEN YELLOW-------356-381C
RAL. 840 HR SIGNAL RED 3001
RAL. 841 GL ULTRAMARINE BLUE 5002
modelrallysport.com
http://www.modelrallysport.com
Andrews Heat for Hire PAINT CODES Empty Re: Andrews Heat for Hire PAINT CODES
Post  RORY O CONNOR Fri Apr 20, 2012 12:10 am
What are the Halford colours?
Post  modelrallysport.com Tue May 08, 2012 1:27 am
sorry Rory cant help you with that one
modelrallysport.com
Post  Cowley Mon Oct 14, 2013 10:05 am
I wonder if anybody has found the Halfords or Tamiya colour references that match the Heat For Hire colours yet, as I have a potential job on the horizon that will need 'HFH'-ing! Wink
Many thanks.
Post  Cazzo Mon Oct 14, 2013 6:01 pm
Check with your local Halfords DC, They should be able to mix RAL & BS colours,
If they can't then a Motorfactors that can mix paint into aerosols will do the RAL & BS colours
Post  Cowley Mon Oct 14, 2013 9:57 pm
Many thanks Colin, I'll go and make some enquiries once I know exactly what the job entails. Wink
Post  gaz_bass Tue Oct 15, 2013 3:32 pm
GMR told me the yellow was a camel yellow by Tamiya
Post  Cowley Tue Oct 15, 2013 4:08 pm
That's awesome news Gary - even more so as I have a tin of Tamiya Camel Yellow TS-34 already in stock! cheers
